This lesson guides you through configuring your Windows computer (host machine) to download, view, and edit code from the Core2 for AWS GitHub repository. After you complete these steps, your computer is ready to compile and upload code to the hardware’s flash memory. These steps are required to install the ESP RainMaker agent.
Git is a widely adopted distributed version control system that is commonly used for source code management and collaboration. Git also lets users track file changes, and distribute code between a local machine and a remote server (for more information, see About Git ).
OpenSSL provides a toolkit for secure communication to the Git repository (for more information, see OpenSSL ).
Complete the following steps to install OpenSSL, Git, and Git’s dependencies:
The device communicates with the host machine through a Silicon Labs CP210x USB-to-UART bridge. The on-board CP2104 bridge facilitates host communication with the ESP32-D0WD microcontroller. The microcontroller communicates bi-directionally over UART 0, which the CP210x bridge translates through a virtual communication port on the host machine.
Before you can mount the virtual serial port and communicate across it, you must download and install the supporting driver. Complete the following steps to install the driver for the CP2104 bridge:
Python is an interpreted language that is used by the PlatformIO installer that you’ll run later. If you don’t have Python installed on your host machine, download it from here . Make sure that the option to “Add Python to PATH” is checked.
Visual Studio Code (VS Code) is an open source integrated development environment (IDE) that allows you to view, edit, and manage code and more. Download the latest Visual Studio Code for your operating system. To troubleshoot issues with Visual Studio Code installation or usage, refer to their documentation .
PlatformIO (PIO) provides a professional embedded development platform that simplifies embedded software development. This VS Code extension combines the functionality of the Platform IO command line interface (CLI) with a graphical user interface (GUI).
Complete the steps outlined in PlatformIO’s installation instructions to download and install the VS Code extension.
Restart VS Code after the PIO installation completes.
All of the projects exist in a GitHub repository . Through this repository, you can clone the instructions, and view the revision history of each file in the repository.
Complete the following steps to clone the code for the tutorials:
https://github.com/m5stack/Core2-for-AWS-IoT-EduKit.git
The ESP RainMaker phone application is available for iOS and Android phones to provide Wi-Fi network configuration, user-creation, user-device association, and device control.
Install the ESP Rainmaker application through:
If you don’t have a compatible Android or iOS device, follow the ESP RainMaker CLI Setup instructions.
If you haven’t already, unbox the Core2 for AWS and connect it to your host computer’s USB 2.0 port using the supplied USB-A to USB-C cable. (You do not need to use the hex key that is included at this time. This key is used to install additional modules that are sold separately.)
The device should automatically turn on when you plug it in. If it doesn’t, press the power button.
Now that the device is ready and the prerequisite software is installed, let’s identify the virtual port your device is using so that you can correctly route read and write operations.
COM3
). Write down the device port number. (Note: When you disconnect and reconnect the device to your host machine, the port number can change. Be sure to confirm this port each time.)Now that your host machine can communicate with the Core2 for AWS, continue to the next chapter — Run the ESP RainMaker Agent .
AWS IoT Kit now features direct access to
AWS re:Post
, which is a community-driven, questions-and-answers service. Search re:Post using the
AWS IoT Kit
tag to see if your question has been asked and answered. If not, ask a new question using the AWS IoT Kit
tag.
